Results 1 to 10 of 18
Thread: Rear wheel leak?
    Question Rear wheel leak?
    Came home after a nice drive to this. Looks like it has been doing it for a little while. My first thought is slave cylinder? some factors trouble me though. First off i am not missing an brake fluid. when i hit the brakes the car does pull it to the left which means i am having brake issues. No grinding or anything but does seem like a loss of pressure. I checked the bleed valve and it is tight. anything else it could be?
    Does it stink? Could be gear oil from the rear end coming around the bearing / seal.
    And that was my other thought.... It does kinda stink. smells kinda like burned rubber every once in a while.. Not strong like rubber but does have a smell..And the whole top of the drum is dry which is where the cylinder is.
    Just thought about this. on my way home i was on the highway doing about 65-70 and when playing with it it stuttered and was feeling jumpy as if the tranny had some play in it. the motor sounded fine for the most part except dancing with the tranny. could that be because i have little oil left in the pumpkin?
    Sep 2009
    phoenix az
    looks like a rear wheel grease seal leak pull the wheel and the drum and see where it is comming from. also if it is the wheel seal you will also have to make sure the air vent on top of the rear end is open and not clogged to prevent this from happening again
    Senior Member Wades GT's Avatar
    peoria
    Anal leakage!!!! What have you been doing Austin?
    Just Kidding. That is a axle seal leak, with that fluid gone and you don't see any brake fluid missing that leave only one option.
    http://wildwestmustangsaz.com/gallery/albums/userpics/EVIL SIG.jpg
    So would it make the drive train feel funky when driving without any fluids? how would you go about puting fluid in and the seal? i am going ot pull it apart right now.
    peoria
    Quote Originally Posted by Mr. Austin View Post
    Yes it would. There should be a fill plug on the front upper side of the diff housing.
    Feb 2009
    Peoria, Arizona
    your over thinkin stuff brotha!! If it is what wade said you dont need to pull the thing apart. Hopefully its an easy fix so u can go with us in Feb.
    this is a two hour repair tops..and half a six
