Results 1 to 4 of 4
Thread: 88 ignition switch
    Texas
    88 ignition switch
    Anyone with information on how to change out an ignition switch on a 88 mustang?
    Sep 2009
    phoenix az
    if I remember corectly its at the base of the steering column two
    screws and a plug with a long wire (like a piece of coat hanger) that runs
    up to the lock on the column not hard to do I'd have to look at it to remember
    how it comes apart been awhile since I did one
    if its not the column lock setup then a paper clip and your key paper clip goes in the
    little hole turn key to left as far as it goes lock will come out undo lock ring switch falls out unplug wires and put the new one in
    piece of cake.. you'll need a tamper-proof torx i think its a t20 or t25..
    Texas
    88 Ignition Switch
    Thanks so much for the reply's, apparently mine came apart internally which prevented turning the switch from the off position. I had to drill the switch out.
